conversion kit to redesign the MAX IV
+ Reply to Thread
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 34
Thread: conversion kit to redesign the MAX IV
  1. #11
    Join Date
    Aug 2011
    Location
    Kotzebue, Alaska
    Posts
    1,209
    Maxrules... Thank you. I wasn't aware the Buffalo used a lengthened MII frame.
  2. #12
    Join Date
    Mar 2014
    Location
    Lake City, Florida
    Posts
    288
    This is a reply that i got today from them:
    The kit was a frame addition to hold the T-20 correctly, the rear and center sprockets, 4 axles, clutchs were custom along with many other parts.
    Cooling system and exhaust was a big issue, see the photos that we still have on the web. I will mark the project "sold out' on the website.
    The kit needed to be part of regular production upgrade from the factory, as it was just too expensive/hard work to update completed machines.
    Its a shame, because the modified machines were really nice and drove so well.
  3. #13
    Join Date
    Aug 2013
    Location
    Hilton head SC
    Posts
    315
    I know I'm a bit late on this tread but im getting ready to redo the max 4 after the October Busco ride. I'm going to be relocating the t20 and dropping the engine down.. Not really worried about exaust, that's an easy fix.. Just tear it apart and make it better... Didn't mike do this to his max 4? ( if I remember correctly it was a prof job). Norm...
  4. #14
    Join Date
    Aug 2011
    Location
    Kotzebue, Alaska
    Posts
    1,209
    Quote Originally Posted by Normable1973 View Post
    I saw in a video his engine was behind his seat. Let us know how your conversion goes.
  5. #15
    Join Date
    Jan 2011
    Location
    northern Wisconsin
    Posts
    892
    I like the idea of the conversion but gotta believe the engine and tranny are stacked for balance in the water. I fish out of mine a lot with two adults in the front seat and it floats so nice. I think that's why the front axel is further ahead as well. I go 240 and the girl friend..... Well better not say (lol). But it floats nice and level I'd like to see how one floats with the conversion, maybe not much difference. Should be more stable anyway.
  6. #16
    Join Date
    May 2009
    Location
    NJ 08533
    Posts
    5,052
    Quote Originally Posted by tbone9 View Post
    You'll have to get together with LarryW and see side by side, I'd compare the Buff but can't see it with me in it.
  7. #17
    Join Date
    Jan 2011
    Location
    northern Wisconsin
    Posts
    892
    Ha ha I'm sure you could find a driver Jim. Larry had really nice setup there. Kinda simple too.
  8. #18
    Join Date
    Mar 2014
    Location
    Lake City, Florida
    Posts
    288
    I know one thing richard did was to "center" the motor during the conversion process. When i go in deep water my max 4 will list to the left very easily compaired to leaning to the right, which takes a bit more effort. I still plan to do this conversion on my own since there is no kit for sale. I rarely take my max in the water so thats not a reason for me to do this. However, to get to the rear axles and chains....now there is a good reason to do it. I hate the idea of pulling the motor all the darn time to get to things that should have been better designed from the plant. If its a routine maintance item, it should be easy to access. I'm not a little guy so its pretty tough to fit into the smaller recesses to make adjustments and grease everything. I just ordered the conversion kit from adair argo (for all 6 axles) to go from factory bearings to the larger argo bearings. Thats gonna be fun. But its primarily being done because poor access to the rear axles leads to poor maintaince which inturn leads to premature bearing failure. So i figure if i beef them up and then get the above mentioned conversion built as soon as i can make time, it will all lead to a max thats much easier to work on and has stronger parts in the end.
  9. #19
    Join Date
    Jan 2011
    Location
    northern Wisconsin
    Posts
    892
    Sounds like a major renovation. But it will be nice when you're all done. Hopefully you can post some pictures.
  10. #20
    Join Date
    Aug 2011
    Location
    Kotzebue, Alaska
    Posts
    1,209
    Yes, pictures. Very interesting stuff.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
