Ok so I can't figure out why the right front axle bearing concentric collars, both inboard and outboard keep coming loose on my Max IV. I only have about 2 hours of total ride time on the machine since the rebuild and this is the 3rd time both collars have come loose allowing the axle to slide outward about an inch. I figured after the first time it happened I might not have secured the collars and set screws properly. Ok so I put everything back together and rode it about an hour with no apparent problems. I get home to clean up the machine and check the chains and find that both collars have come loose again and the axle has slid outboard the same amount (2nd time). So for the third time I tighten the collars and set screws. Today I ride it for about 10 minutes and check the collars and find that they are again loose and the axles has slid out (4th time).
So I defer to all you Max folks out there to help me solve this mystery. I'm sure that someone has encountered this before. Help me out.
Specifics, the solid axles are original as far as I know and are on a '95 model. The following are new; bearings/collars are matching sets, flanges and hardware. No issues with loosening of any other flanges on the machine.
Thanks in advance for the advice.
