Max modifications for winter
+ Reply to Thread
Page 3 of 7 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 62
Thread: Max modifications for winter
  1. #21
    Join Date
    Jan 2011
    Location
    northern Wisconsin
    Posts
    892
    Quote Originally Posted by BadBradII View Post
    Can you post a picture showing how they are secured to the track
    Brad, here's some pics for you. The uhmw is attached with 5/16" elevator bolts and the locknuts are countersunk. The stainless is through bolted with 1/4" bolts. Despite the way better traction I found the cleats to make the track more ridged and a lot less chance of running out of them if a tire loses air pressure. I also attached a picture of the drill bit needed to go through the rubber.
  2. #22
    Join Date
    Jan 2011
    Location
    northern Wisconsin
    Posts
    892
    Quote Originally Posted by JoeMeg View Post
    Lookin' good,Trevor. It's nice to be able use some of the empty spaces for storage.
    Thanks Joe, sorry I won't see you at Ash this weekend. Life just gets in the way sometimes.
  3. #23
    Join Date
    Jan 2011
    Location
    northern Wisconsin
    Posts
    892
    Cab heater
    Last year I rigged up a heater from a forklift under the front seat angled up towards the windshield. I plumbed it off of the liquid cooled Kawasaki. Along with a two speed fan controler it got plenty warm enough. Still had to mount a fan up on the roll bar aimed at the windshield to defrost it. Along with the windshield wiper it's a lot easier to see. ( more on the wiper later). Just thought I'd pass this along if some of you are looking for heat this winter.
  4. #24
    Join Date
    Oct 2015
    Location
    Connecticut
    Posts
    9
    Quote Originally Posted by msafi65 View Post
    On my 27 horse IV I remove the outside air tube and turn the air cleaner body to face the exhaust for winter use. really cut down on carb ice. If yours is injected it probably won't make much difference. The air cooled ones are a bear for carb ice if you don't do something to raise air temp in cold weather.
    could you at all send a pic of what you did? I just acquired my first max iv and the 25hp engine is having trouble right now with the cold weather. if I try to move it at all without waiting at least 30 minutes for it to warm up it stalls, but as soon as it warms up it could run forever
  5. #25
    Join Date
    May 2013
    Location
    Benton, Maine
    Posts
    63
    I'm going to make one like that. I like it
  6. #26
    I would like to know the same thing
  7. #27
    what did you use for the cleat was it a peace of angle made of aluminum??
  8. #28
    Join Date
    Jan 2011
    Location
    northern Wisconsin
    Posts
    892
    I'm assuming you're talking about the cleats on the tracks? They're stainless flat bar. 1 1/4"x 1/8"
  9. #29
    Join Date
    Jan 2011
    Location
    northern Wisconsin
    Posts
    892
    Max windshield wiper
    Finally got the windshield wiper done. It will come in handy when going through the trees when they're flocked with snow. Ill no longer have to stop get out and brush it off. I can park the wiper anywhere with the one speed motor.
  10. #30
    Join Date
    May 2009
    Location
    NJ 08533
    Posts
    5,052
    That's a good size wiper hitting most of the windshield, the heater on water cooled is a great idea for those in the cold. Is it under the driver seat or the rear seat?
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
