1980? Max II general questions
+ Reply to Thread
Results 1 to 5 of 5
Thread: 1980? Max II general questions
  1. #1
    Join Date
    Feb 2008
    Location
    northern CA
    Posts
    210
    Hi gang!
    so, I'm back.........this time with the above titled rig.
    Any specific things to check/look for/change/ fix?
    It's a 2 stroke engine. I'd eventually like to change to 4 stroke.......we'll see I guess.Any input appreciated.
    Henry:
    I don't know where I'm going, but, I'm on my way...........
  2. #2
    Join Date
    Sep 2012
    Location
    Hanover,PA
    Posts
    1,012
    Biggest problem with that machine is the inner axle Bushings wear out. The Brass and Not a Bearing like the newer one's. Check you axle play (up & Down) other than that it's a real easy machine to up grade to a 4 cycle motor All though I Like the 2 smokers !!
    Post some pics when you can.
  3. #3
    Join Date
    Apr 2013
    Location
    Duluth, MN
    Posts
    57
    I have 2 1980 models with 4 stroke vanguard. Love them both.
  4. #4
    Join Date
    Feb 2008
    Location
    northern CA
    Posts
    210
    ah ok, thanks wedge. I'll check the play. Yeah, I'd prefer a 4 stroke. Gonna see what's around. About what would the lower H.P. be that's workable?
    I have a pretty complete machine shop here in my shop, lathe, mills, drill presses, cut off saws, MIG, arc, and gas welder and plasma cutter. Is there a preferred swap as far as bearings go?
    Also weighing buying or trying to make tracks for snow.
    Henry:
  5. #5
    Join Date
    Nov 2009
    Location
    Charlotte, Mi/ Houghton Lake Mi
    Posts
    2,910
    The problem with inner axle bushings is not the fault of the bushing itself, it is the fact that there is no provision for greasing them.
    There is however an easy fix......the axles are hollow...add a grease zerk.
    It will fill the whole axle with grease and some will ooze out the bolt hole making a small mess, but grease does get to the bushing.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
