hey guys thanks for the add i just picked up a 02 max iv with 175 hrs for a good deal has 26 in tires but outer bearings are toast and I just started tearing this aatv apart tonight and I want to replace all chains and I need the the size and links for it also looking for a rear splined axle and new rear sprocket mine missing some teeth also had to cut out the axle too someone broke the set screw in the sprocket so I had to do major surgery that is going to cost me what are some good bearings to run on this beast thanks.
