Max IV disc brake photos
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
Thread: Max IV disc brake photos
  1. #1
    Join Date
    Mar 2013
    Location
    San Francisco Bay Area
    Posts
    328
    I was just the lucky recipient of the Max IV brakes that Whipper was giving away and I'm looking for a photo of how they go in to make the install easier.
    I looked on the gallery but couldn't find what I was after. Can someone either point me to something in the gallery if I missed it, or take a photo for me?
    Thanks.
  2. #2
    Join Date
    May 2009
    Location
    NJ 08533
    Posts
    5,052
    This is what JBF did and I would do, perhaps you may do.
    When you search the gallery just type in brakes and many things will come up to sort through.
    Use the search in the blue bar.
  3. #3
    Join Date
    Mar 2013
    Location
    Posts
    328
    Thank you. I'll use that as a starting point. I bought some discs and calipers from MFG, but when I welded the discs to my front sprocket tubes I introduced more runout than I wanted so I put things on hold until I figured out what to do next. That was a few months ago and now I know what I need to do next: Start over with these.
  4. #4
    Join Date
    May 2009
    Location
    NJ 08533
    Posts
    5,052
    That's where they sit, if you have the stock calipers from Whipper it should be a breeze.
  5. #5
    Join Date
    Mar 2013
    Location
    Posts
    328
    Are you saying the discs sit near the front axle, or the center one like the photo you posted above?
  6. #6
    Join Date
    Mar 2013
    Location
    Posts
    328
    Can someone clarify for me, is the original position for these discs on the front or the center axle? From the length of the linkages for the calipers I'm thinking they live near the front axle, not the center one.
    Thanks.
  7. #7
    Join Date
    Jul 2009
    Location
    Cleveland,Oh.
    Posts
    1,589
    I don't own a Max IV but,by looking at the pic Jim posted,it appears the centerline of the brake discs is just behind the middle axle. I'll guess this is somewhere under the rear seat?
  8. #8
    Join Date
    Mar 2013
    Location
    Posts
    328
    Yes, it is in this picture. I'm not clear if this is the original placement as built at the factory, or if this is a modification done with the original discs.
  9. #9
    Join Date
    May 2009
    Location
    NJ 08533
    Posts
    5,052
    Phabib, what year is your machine? The disks picture are the larger 10?" discs used on early IV's in the middle, later machines used either drums or 4?" discs on the front. Max II's should look the same.
  10. #10
    Join Date
    Mar 2013
    Location
    Posts
    328
    What I've got are the big discs. I had band brakes but want to put in the discs. I guess they go in the middle, not the front.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
