The throttle and choke cables are the longest ones made by Max. I don't recall the lengths off the top of my head. The choke is run from the left side of the dash between the upper and lower bodies down the left side of the machine. If you try and run it down the floor it will be too short. The throttle cable runs down the bottom of the machine and comes up before the engine and transmision, but after the battery location. If you try and run it all the way back it will come up short.
