Max 2 bearing cage install
+ Reply to Thread
Results 1 to 2 of 2
Thread: Max 2 bearing cage install
  1. #1
    I am installing cages and have no manual. This is my first time playing with this drivetrain of this type of machine and all the help would be apritiated. I am looking for a install video if out there or a step by step instruction. I also see there are two cages with a plow mount. How do these install, top , bottom>? should there be a bar I need with the cages to link all together? thankyou
  2. #2
    Join Date
    May 2010
    Location
    Fairbanks AK
    Posts
    1,456
    Plow mount brackets are bottom next to tub. What axles do you have? Set screws or snap rings holding the sprockets in place on the axles. I believe the max II chassis manual is on this site. I know there are electronic copies of the manual. I Don't have my computer with the copy available for a couple weeks. With more info I'm sure you will get what you need.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
