Max ii 16hp or 18hp?
+ Reply to Thread
Results 1 to 4 of 4
Thread: Max ii 16hp or 18hp?
  1. #1
    Join Date
    May 2014
    Location
    LANCASHIRE, UK
    Posts
    203
    Hi Guys
    I have 3 Max II, Two 16HP and one 18HP,All three have Briggs & Stratton V twin Vanguard engines, and time to sell one too many toys lol
    Red one,16HP no running problem since fixed the slipped sprocket,lose stater wire.will red fade in time and look tatty? just has a cut in the rear top tub with the last owner pulling the pull start making it cut into the upper tub.
    Green one 16HP ,missing two head lights.Need to replace bent axle and middle bearing(new axle and bearing now got)
    Brown one 18HP, One bearing needs replacing ,missing one head light, engine revs up and down on tick over,only just started doing this today(on ebay)
    All are 2001, two have sunk upper tub above engine the other is flat (red one)
    , all have full roll cage.
    not sure if I am selling the right one? is it better to keep more HP? or change engines?
    mmmhhhh
    Richie
  2. #2
    Join Date
    Mar 2014
    Location
    Lake City, Florida
    Posts
    288
    If I was buying I'd always want the higher hp model, no matter what it is. If I'm selling I'd keep the one that would have the most life left in it and required the least amount of work. That said if u have one you favor more, keep that one. It's your decision here and not one we should make for you.
  3. #3
    Less maintenance required, best looking, most HP without a doubt
    Our motto in the Strategic Air Command was "Peace is our Profession". If you don't believe it we'll bomb the hell out of you.
  4. #4
    Join Date
    May 2014
    Location
    LANCASHIRE, UK
    Posts
    203
    Thanks, think I will hold off selling one till I make one good one with the bigger HP,looking like an engine change.
    Richie
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
