What size chains?
+ Reply to Thread
Results 1 to 5 of 5
Thread: What size chains?
  1. #1
    Join Date
    Apr 2014
    Location
    Ogdensburg, NY mailing but live in Morristown, New York
    Posts
    31
    What size chains?
    Hello everyone. I have a 1996 Max II with a Serial number of 13404. I would like to know what is the proper size roller chain to replace all the chains? Also, what is a good chain to replace them with? Thank you.
  2. #2
    Join Date
    Oct 2007
    Location
    Texas
    Posts
    2,161
    The bulk of the chains will be #50, the half shafts should be #60. I would buy Diamond brand, Tsubaki, or some other high strength brand. Don't buy the cheap chain though because you will quickly regret it. Good quality #50 should have a tensile strength of 6500 lbs or higher, #60 should be 8000 lbs or higher. If you splurge anywhere on the machine, do so on the chains.
    If you aren't in a hurry, you can often find the good stuff on EBAY or Amazon for next to nothing.
  3. #3
    Join Date
    Apr 2014
    Location
    Posts
    31
    Thanks Master Mudder for the tip
  4. #4
    Join Date
    Aug 2011
    Location
    Kotzebue, Alaska
    Posts
    1,209
    Hi... www.mfgsupply.com sells O-ring chain that equals the tensile strength of Tsubaki but ay half the price.
    Check under the "motorcycle" section for drive chain.
  5. #5
    Join Date
    Apr 2014
    Location
    Posts
    31
    Thanh you very much
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
