New to forum and 6 wheelers
+ Reply to Thread
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 28
Thread: New to forum and 6 wheelers
  1. #11
    Join Date
    May 2009
    Location
    Meadville, Pa
    Posts
    3,286
    Are you looking for an original 3-lug hub axle or a 5-lug axle of a newer machine. I have both styles laying around used but in good usable condition
  2. #12
    3 hole is what i have
  3. #13
    Also found the sprockets where they bolt to the axle are all loose and egg shaped. It appears some are cracked.
  4. #14
    Join Date
    Jun 2007
    Location
    Buffalo, NY
    Posts
    6,442
    Quote Originally Posted by lowrider View Post
    Are yours the #40 chain or #50 chain sprockets? Amphibiousdrew or I have a couple extra sprocket sets laying around for you.
  5. #15
    the chain from the transmission to center sprocket is 50 from center sprocket to center wheel 60 from center sprocket to front and back sprockets is 50
  6. #16
    Join Date
    Jun 2007
    Location
    Buffalo, NY
    Posts
    6,442
    I think I have an extra set of good condition #50 chain sprockets floating around.
  7. #17
    Have transmission back in, now input side won't shift into forward. was working fine on bench. Also need shims for jack shaft, any ideas
  8. #18
    Join Date
    May 2009
    Location
    NJ 08533
    Posts
    5,052
    Rock it.
  9. #19
    Join Date
    Mar 2016
    Location
    Jamestown, North Dakota
    Posts
    193
    These t20's on their best day shift pretty tough. Don't let the gears grind.
    Rocking it back and forth, and my trick that works is to pull the sticks back, press the shifter down gently, let them snap forward. It will usually fall into gear.
    Your t20 operates like two divorced differentials, meaning the operate independently from each side. The best mod to make it shift easier, is to cut the shifter in half so you can shift each side independently, so they won't fight eachother when trying to shift. It's much easier to line up one gear at a time than two simontaniously, it also gives you the option to run one side in forward and the other in reverse.
  10. #20
    Join Date
    Mar 2016
    Location
    Posts
    193
    welded up split shift - Amphibious ATV Pictures
    This photo in the gallery is te best example I could find of the easiest split shifter.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
