If you can find a small hollow pipe that will slide around the shaft that ties the two together, cut it, slide it over, (the pipe keeps the levers straight) weld the extra pipe onto it to make a "T" shape, and just get a ball from an old lawn mower or replacement from a hardware store. There's a lot of different ways to do it, when I get mine done il post pics and a parts list.
thanks again for the help.If your installing a different motor, what is the best distance for the motor to transmission. How do you determine what length of belt you would use.
dirtdobber's link is great. What I normally do is put the motor and trans in the ATV and move it around until I get it where I want it. Then I measure the belt needed and see what is available that is close to that distance.
