1995 max IV chain tension sprocket.
+ Reply to Thread
Results 1 to 3 of 3
Thread: 1995 max IV chain tension sprocket.
  1. #1
    Join Date
    Jul 2013
    Location
    Andover MA
    Posts
    24
    My max IV has the chains going over the top of the sprockets, versus under. Does this matter? Having to pull the sprockets up to tighten the chains, isn't fun. Should I change them to under? Also if there is any play side to side, should I replace the 4 sprockets?
    Thanks
    Mudslinger
  2. #2
    Join Date
    May 2007
    Location
    Kings Mountain, NC
    Posts
    7,788
    The tensionors should be on top of the chain, pushing it closer together. It shouldn't take too long to get things swapped around. For the lateral movement, they will usually have a little. Movement here isn't quite as critical as play in your main sprockets or axles but you still want to keep it to a minimum. If it is really wobbling, then you will want to replace the sprocket. If it's just a little movement then you should be fine.
  3. #3
    Join Date
    Jul 2013
    Location
    Andover MA
    Posts
    24
    Thanks mike. I switched out two of the sprockets as their bearings were shot. Two were fine. Thanks again for the info.
    Mudslinger
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
