Where to buy bearings?
+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: Where to buy bearings?
  1. #11
    Join Date
    Jan 2011
    Location
    northern Wisconsin
    Posts
    892
    I got my bearings from Buffalo also however I changed it up a little bit and went with the bearings that have two set screws to the axle for the outer bearings as I've seen the lock collars break loose or just break altogether. The lock collars are more geared towards a one direction application. Buffalo doesn't stock these but they can order them. Here's the numbers if you're interested. Hope this helps.
    Outer UC-207-20 R3
    Inner UC-206-17
  2. #12
    Join Date
    Aug 2011
    Location
    Kotzebue, Alaska
    Posts
    1,209
    Tbone9... Thank you. Does the set screw style eliminate the need for lock collars, or is it in addition to lock collars? Thanks.
  3. #13
    Join Date
    Jan 2011
    Location
    northern Wisconsin
    Posts
    892
    Eliminates the lock collar all together. They'll have two set screws just like the inner bearings. Just put antisieze on the screws. We use this style bearing in industry a lot.
  4. #14
    Join Date
    Aug 2011
    Location
    Kotzebue, Alaska
    Posts
    1,209
    Thank you very much.
  5. #15
    Join Date
    Aug 2011
    Location
    Kotzebue, Alaska
    Posts
    1,209
    Regarding the set screws, would there be a need to drill dimples in the axles for the set screws? I ask because the Avenger we owned had dimples for the set screws on the sprockets. Makes sense, but unsure if it would apply to bearings. Thanks for all the help.
  6. #16
    Join Date
    Jan 2011
    Location
    northern Wisconsin
    Posts
    892
    I didn't drill them because because we never do in industry, but definitely for the sprockets.
  7. #17
    Join Date
    Aug 2011
    Location
    Kotzebue, Alaska
    Posts
    1,209
    Tbone9...Thank you.
    AkCtawler... Thanks for the tip.
  8. #18
    Join Date
    Jan 2011
    Location
    northern Wisconsin
    Posts
    892
    No problem. Keep that Max healthy so you can find more Mamoth parts. What cool hobby!
  9. #19
    Join Date
    Aug 2011
    Location
    Kotzebue, Alaska
    Posts
    1,209
    Thanks. This is exactly why I'm fixing up our Max IV, and collecting spare parts. Looking for mammoth tusks, teeth, and bones us a nice hobby. Gets us outside and riding. I prefer the Max over any quad now. More fun.
+ Reply to Thread
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
