max doesn¨t steer in reverse
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: max doesn¨t steer in reverse
  1. #1
    Join Date
    Jul 2015
    Location
    Florida
    Posts
    57
    My max iv does not steer in reverse. I assume it my need some adjustment to linkage? thanks for any input
    Max IV
    Dodge Ram 2500 4x4
    swamp buggy powered by 1947 willys flathead
  2. #2
    Join Date
    May 2009
    Location
    NJ 08533
    Posts
    5,052
    Pushing the sticks forward?
    The drive in forward is the brakes in reverse & opposite.
  3. #3
    Join Date
    Jul 2015
    Location
    Florida
    Posts
    57
    Quote Originally Posted by ARGOJIM View Post
    If you pull both sticks back at the same time in reverse it works, but when you pull one stick back it seems to slip and not want to go
    Max IV
    Dodge Ram 2500 4x4
  4. #4
    Join Date
    May 2009
    Location
    Meadville, Pa
    Posts
    3,286
    Ditch the springs and try it again.
  5. #5
    Join Date
    Jul 2014
    Location
    Mississippi
    Posts
    82
    I had the same problem and one of my **** rods was slightly bent...took it off, heated it up and straigtin' it out...all good now.
  6. #6
    Join Date
    Jul 2014
    Location
    Mississippi
    Posts
    82
    Shift rods not **** rods
  7. #7
    Join Date
    Sep 2008
    Location
    woodland pa
    Posts
    534
    make sure the steering sticks have a enough clearance in the tub holes. And the shifter has enough clearance. Is it split shifted? Do not think this is your problem but worth checking, GOOD LUCK
  8. #8
    Join Date
    Jul 2015
    Location
    Florida
    Posts
    57
    Thanks for the reply's!
    Max IV
    Dodge Ram 2500 4x4
  9. #9
    Join Date
    Sep 2014
    Location
    southern MD
    Posts
    36
    Sounds like mine, insure that both sides of tranie are all the way engaged, if not one side will pop out n reverse making a horrible noise.
  10. #10
    Join Date
    Jul 2015
    Location
    Florida
    Posts
    57
    It looks like I didn't have both sticks in right position but seems to steer but very sensitive in reverse.
    Max IV
    Dodge Ram 2500 4x4
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
