After fighting with what should be an easy belt change on my 25 horse I came up with an idea maybe it can help some others. I slotted the engine stand so I could unbolt the clutch and loosen foot bolts on the engine then slide the engine off of the clutch allowing the clutch to drop down allowing more slack. Also welded some stop blocks to slide the engine back to starting position. Hope someone can benefit from this.
