Originally Posted by
tonyk72
I used an aluminum wire screen and scraps of poly to do my repairs. I took the screen and melted it into the poly all around the crack using a soldering iron. Then I took very thin layers of poly salvaged from potting containers and melted/pressed them into the wire mesh using a heat gun and an auto body dolly. I probably used about 4-5 layers of poly to complete the repair. The weld held up after pounding it with a rubber mallet and pretty hard riding. To make it pretty, I sanded the rough spots and lightly melted the roughness with a heat gun to give it smooth appearance. Prior attempts to fix without the wire mesh failed miserably.
Here a some pics of the damage and work in progress attached....
