I am installing new #60 chain on my Jackshaft on my 91 MaxII. Every time I spin my wheels the chain binds up between the top and bottom gear. I know the shaft is out of alignment. I plan on using a caliper depth gauge to align the jackshaft to the frame. Question: do I automatically assume the lower gear is true to the frame? Also can I use the depth gauge to measure from the top of each side of the Jackshaft to the top of the frame. Observation: #60 chain has zero side to side tolerance and will tell you things are not lined up.
