Bigger is better in most cases. You won't be hurting for acceleration or ground torque with the smaller tires, but will give up valuable ground clearance and water speed/buoyancy
If you don't Need 24's on your car you don't Need 26's on your machine if you have no intention to mud (unless you want to climb downed trees ( not branches)), 22's ride much better and will essentially keep the machine geared lower for more power.
I run 22's for years (on an Argo) and don't like the 26's stiff ride or the 25's bounce, but for going to Busco to intentionally get stuck, bigger is better for less stuck. The 25's ride is less shocking than the 26's in the Buffalo.
I have a 2005 Max IV. It uses 530 chain. I tend to think they all did. I read here that some modified theirs to use 60 chain. Perhaps yours was modified? (Of course I could be completely wrong)
When I called recreative Industries the guy I spoke too said that the older machines like mine used #60 and the newer ones including the buffalo use 530. He couldn't confirm that I could use 530 chain would work in my machine but when I asked what was the difference in the pitch from the old style sprockets to the new ones he said that to his knowledge they were the same. But I might want to check on this web site.
If your machine used 60 chain then 530 will not fit. You would have to use 60 chain or replace all sprockets to use 530 chain.
Ok. So I think I have this figured out. When I bought this max I was told by the owner that it used #60 chain but 530 would work on it. He even gave me 20 foot of new #60 chain. so I just took him at his word. He DID have about a dozen 6x6s laying around.
So after pulling the sprocket and some chain that was still on the machine I quickly found that it is in fact 530 throughout the machine. So problem solved.
Next I pulled the ignition and it does have 5 pins on the back. So any help on finding a key for this would be appreciated.
Next question:
This max has 5 hollow axles and one solid. I am assuming the solid axle must have been to replace a damaged one.
So...I'm thinking about using what's in it for now but maybe getting one more solid axle putting them wher the machine is most prone to bending axles.
My question is where should I put the solid axles first? I would think the front would be the most vulnerable. Is this correct?
What bends? Is the axle tube itself? Or is it the hub?
The older machines with through bolts used 60 from the trans to the jackshaft or rear sprocket, the II's started with 40 elsewhere, later 50. I never owned a bolted IV so that chain could be either 50 or 60 ( should be obvious), the later machines used 530 and 520 oring chains.
Does the axle bend or the hub?
