If you are going to use the hollow ones add gussets to the hub. Your solid axle should be that way if it isn't a forged hub type. Check all axles for straight either on V blocks or in a lathe. If they are bent replace them as they will break at the bolt hole in the future. I posted a chain specs page a few weeks ago. The 4 used # 50 chain throughout and 530 is direct replacement. Only place you can't use 530 is in a vehicle that won't accept the wider chain. The ignition switches I use come from manufacturers supply. 5 pin part # is 31-9330. The 7 pin that I usually upgrade to is 31-9623. The wiring diagram is on this site and max6x6.com. The 7 pin gives a true accessorie feed.
