I have a question. When installing bearing cages you will still keep the outer bearing at the body but add another one in the bearing cage correct?
I'm wondering the same thing?
There will be a bearing flange on each side of the cage. One between the cage and the body and one outside of the cage.
These cages allow three bearings per axle?
(I had thought the outer was moved to the cage end)
Does the third bearing allow for better bearing life over two? Thanks
The three bearing set up supports the axel all the way out to the end. A must for running tracks. Bearing life all depends on usage.
Thank you.
THANKS!
With ultimate bearings you wont need the cage . Ever.
What ultimate bearings? I bought the ones from Buffalo Bearing "everyone" says to buy. Are these them? Thanks.
