Max II bearings and flanges
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
Thread: Max II bearings and flanges
  1. #1
    Join Date
    Mar 2016
    Location
    Jamestown, North Dakota
    Posts
    193
    Found out 2 of my zerks are broke off, 1 bearing pushes all the grease out the collar, 2 push all the grease out the outer flange.
    Long story short, new bearings.
    I have Non-splined axles, and it looks like a type of bushings on the inside.
    What do I all need to replace the bearings, inner flanges, and bushings? If I got it apart I'd like to go all the way.
    Most likely be ordering from buffalo bearings. R3 type. 3 bolt.
  2. #2
    Join Date
    Jan 2015
    Location
    Dallas, Texas
    Posts
    178
    Tool wise, you'll need a basic socket set, allen wrenches, a wrench set, and a hammer and chisel. Oxytorch, grinder and a hydraulic press are optional for stuck sprockets, bearings and eccentrics. To ease the process of replacing bearings the next time around, a little anti-seize is a fantastic idea.
    For new hardware, depending on the year of your machine, you'll probably want and need 6 new zerk-less flanges, 6 new zerk-ed flanges, and 6 new 1.25" ID 207 bearings. That will cover your outer bearing setup. For the inners, you'll want 6 new inner bushings or pillow block bearing depending on the year of your machine. Mine is a 2003 max 2, and it uses 6 pillow block bearings ( cant remember the footprint dimension off the top of my head), 1.25" ID, 206 bearings. Yours may be different depending on the year. Make sure to check your parts over to make sure you get the right stuff.
    Meep Meep
  3. #3
    Join Date
    Mar 2016
    Location
    Posts
    193
    Thanks! Would it be possible/necessary to convert to inner bearings and eliminate the bushings?
  4. #4
    Join Date
    May 2009
    Location
    NJ 08533
    Posts
    5,052
    Rabbit your machine probably does not have 207 bearings but 206 bearings. You may be able to install the cast iron inners if there is enough room but don't order 6 of them on my account, you would have to try one on each axle for frame fitment.
  5. #5
    Join Date
    Mar 2016
    Location
    Posts
    193
    What is the difference between 206 and 207? Are we going by axle shaft size?
  6. #6
    Join Date
    May 2007
    Location
    Kings Mountain, NC
    Posts
    7,788
    206 is a 62mm bearing and 207 is a 72mm bearing. That is the outer ring size.
  7. #7
    Join Date
    Mar 2016
    Location
    Posts
    193
    So they are not interchangeable? Is one not better than the other? Because if I get te flanges and the bearing all the same size, they should fit right?
  8. #8
    Join Date
    May 2009
    Location
    NJ 08533
    Posts
    5,052
    The hole in the frame is smaller
  9. #9
    Join Date
    Mar 2016
    Location
    Posts
    193
    alright ill have some 206's coming on monday from buffalo bearings. i wonder if there isnt a reason we dont put those big heavy bearings with the thick pillow block on these instead of these split flange units.
  10. #10
    Join Date
    Jan 2011
    Location
    northern Wisconsin
    Posts
    892
    The bolt pattern on the cast pillow block is too wide for the frame and they're not triple sealed. I wish there was room for an industrial type bearing and housing.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
