Hi. My wife and I are fixing our M-IV today. I noticed both diamond shifters were stuck. We got them out easy enough. It did the same last year, after sitting all winter in storage.
I used ATF fluid as lube last year, and the shifter 'froze'.
Well, can I use marine grease to lube the diamond shifters?
I ask because its not wise to mix oil with the trans fluid, and grease is made from oil. Oil ruins the brake band liners.
What do you all use to lube the shifters? Thanks.
