I've had consistent noise at the rear chain, everything it's under a little load. Pretty sure it's from the t20 drive chain. I've pulled the tranny three times. No matter what it still has some clunk to it. Any ideas?
Last edited by Mike; 07-09-2016 at 11:33 AM. Reason: Moved post out to a thread of its own
I agree with Jim, usually its the idler sprocket bearing, sometimes its just warn out chain that stretched just enough to get loose and bind. On a Max 4, I get the best Diamond brand chain I can find and install it on the T20 drive sprockets. From memory, I think its only 52 links per side, so a 10' box of chain will do the job and give you some extra length for backup. For a frugal guy you could use cheapy chain for the more accessible lengths forward in the Max4. By Cheapy chain I mean anything other than tractor supply cheap. You can get high strength foreign made chain for about the same price as the cheap junk that T.S.C. sells.
If you are really handy, you could also fab up a different mount for the T20 to give an inch or so of adjustment that will extend chain life too. Most Max4s have a light weight tranny mount and the frames could use some reinforcement too.
Have not pulled the motor yet. Noise doesn't seem to bad anymore, I actually think it is my belt. It is loose so it isn't putting enough force on the clutch until it revs up. If I rev it up then turn or engage the machine, no noise. I put new chains on it last time I pulled the tranny.
I had something similar happen to me, I chased it for a few weeks. It only happened going up steep obsticles when most of the weight and traction was on the rear tires, like climbing out of creek beds. It turned out to be the rim slipping inside the tire and adding a few PSI solved the problem but what a racket it made, it sure as hell sounded mechanical.
Watch the clutch in neutral rev up, wore Salisbury's can do that.
I will replace the belt, first. Tires are inflated to about 10 so should be good.
Bikebandit carries Tsubaki chain for a good price. MFG Supply also has chain that is quite good, same syrength as Tsubaki Omega.
Use quality chain. Lasts longer, less issues. Keep them lubed.
10psi was an exaggeration. More like 6, was running it on gravel road while sorting out my noise issue. Good and firm, low drag.
