New to me Max IV. Lots of questions...
+ Reply to Thread
Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 31
Thread: New to me Max IV. Lots of questions...
  1. #1
    Join Date
    Aug 2013
    Location
    Central Kentucky
    Posts
    387
    Hey guys. After years of searching for a 6x6 within a 3-4 drive from me, I found one within 15 minutes. A 1997 Max IV. The body is in really good shape with factory roll cage, windshield, winch, and good looking 26" wheels/tires. The seats are perfect.
    1. Now the fun part. The original owner converted the machine to hydraulic. The next owner (the one I bought the machine from) drove it this way for a while, then he decided to try to return to original. He bought a donor machine for the T20, and he removed all the hydro motors and pump. He (in his 80's) got tired of working on it, and it set covered. I'm not sure what needs to be cut out and what needs to be replaced. I'm trying to look at as many pics of frames to help with this. From what I'm seeing so far, only a couple extra brackets have been made/welded in. I do believe, however, that there are WAY to many sprockets. Yeah. The man assured me it had all new chains and bearings, and they looked great. Oh, and it has no steering or shift levers either.
    2. The T20 was not in the machine, but, rather in a shed. After we made the deal, we were loading the factory windshield, and the man started freaking out about some fluid all over the garage floor. He thought it was ATF from his truck or Jaguar. It wasn't. Rather, it was hydraulic oil from a butter tub on the floor. He was pleasantly relieved, as was I, until he informed me that that was the fluid from inside the T20.
    3. The engine is supposed to be fairly new, and looks to be. The oil is clean, and it has good compression. BUT neither the trans or engine have clutches.
    Now, I don't have too much in it so far. Should I try to buy new parts, source old parts, or buy a donor machine? Also, any suggestions would be greatly appreciated. As far as I know, this is the only Max within an hour or so drive.
    Thanks!
    Kevin
    Oh, and I'll be posting pics in a few minutes. I need to run out and take pics.
  2. #2
    Join Date
    Aug 2013
    Location
    Central Kentucky
    Posts
    387
    Here are some pics. See the extra sprockets? I believe there are extras under the engine. Oh, the engine. It doesn't look like it's mounted in the correct position. Is that even the correct mount?
    There is i pic of all of the other components i have laying on the ground.
    On a good note, I pulled the rope on the Briggs... nothing. Then remembered the key! Pulled the rope and almost passed out! Purred. I unhooked the fuel line before trying to run. Just placed fuel line in a gas can.IMG_3136.jpgIMG_3134.jpgIMG_3138.jpgIMG_3137.jpg
  3. #3
    Join Date
    Jan 2011
    Location
    northern Wisconsin
    Posts
    892
    I can't see your pics too good on my phone. But here's a couple for you to look at. I can see the idler sprockets should be on top of the chain.
  4. #4
    Join Date
    May 2009
    Location
    Meadville, Pa
    Posts
    3,286
    I'm in the same boat as I'm looking at it from my phone. It looks like he included a max II Jack shaft tower and possibly lowered the engine a bit.as tbone said, the chain should run under the idler sprockets.
  5. #5
    Join Date
    Aug 2013
    Location
    Central Kentucky
    Posts
    387
    Thanks everybody. Your guidance is more appreciated than you can imagine. I was showing some guys at church, and had several interested in 6x6s. I may get a following in Central KY!! YAY!
  6. #6
    Join Date
    Jan 2011
    Location
    northern Wisconsin
    Posts
    892
    No problem. You've come to the right place for help. This group is awesome.
  7. #7
    Join Date
    Feb 2013
    Location
    shenendoah valley,va.
    Posts
    2,631
    i'm thinking the extra sprockets i see in the picture have to do with when it was a hydraulic motor system.... and that's why the motor is in a different place also. get some pics off the site of the original max 4 engine and trans setup.. good luck and have fun getting it together. nice the engine runs !! johnboy va.
  8. #8
    Join Date
    Aug 2013
    Location
    Central Kentucky
    Posts
    387
    OK. So I found a possible donor machine. Just need to know how much steering levers and shift lever changed from the late 70's machines to my 96. This one has everything except engine, and I'm sure drive clutch. After doing some more looking today, here's a list of what I need off the top of my head. Steering levers, shift lever, brake, the linkages for shifting and steering, floor pans, engine mount (previous owner cut it down, ugh) throttle cable, driven and drive clutch and belt. yeah, I know.. quite a list.
  9. #9
    Join Date
    Feb 2013
    Location
    Posts
    2,631
    stoney, another option you have is unless you plan on carrying passengers... maybe build it the way mike and a few others have where they mounted the trans in front of the engine and installed just one seat. small floor pan and chains and sprockets exposed for easy repair and maintenance. johnboy
  10. #10
    Join Date
    Aug 2013
    Location
    Central Kentucky
    Posts
    387
    Johnboy,
    The family would shoot me if I did that! haha. This will be a fun and utility machine. I will need the extra seating, so I will be trying to get the machine back to as original as possible. That thought had crossed my mind though.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
