I used the same engine in my MAX II. It works perfect. It does require an additional hot wire for the solinods on the carbs. It works as another kill switch kind of. Did you take off the muffler and go with a straight pipe? If so how much louder is that?
The crank case hose will dump oil into the canister instead of the carb causing the engine to smok on long inclines/declines/angles. For the exhaust, i cut the tubes from the muffler and fabricated a piece, then welded them. I asked the store manager for a friends and family coupon.
