I got a series 40 clutch setup off ebay for my predator engine. Driver and driven and a belt was just under $150(I actually had to buy a second belt after measuring center distance so 180 all in ). On the 7/8 bore driven I had to cut a keyway but that was a 10 minute job with an arbor press and broach. I wanted to make sure I had the proper setup after removing the 2 stroke. And I wanted to do so without spending a fortune.
40 series will not give you the power you need. Change the spring in the original secondary and get the correct primary. I've got a couple of used primary's that are for sale if your interested.
