I'm wondering if anyone here has used anti-seize lubricant as a chain lube? Here's what I found on Permatex's site: Permatex® - Cooper Anti-Seize Lubricants
A premium quality copper anti-seize and thread lubricant that may be used to prevent seizing, corrosion and galling where high temperature conditions exist. Temperature range -30°F to 1800°F (-34°C to 982°C). Provides good electrical conductivity. Meets Mil Spec A-907. Suggested applications: Threaded assemblies, slide fit assemblies, hinges, gears, chains and sprockets cables and sheaves, lever pivot points, rollers, oil-still header bolts, furnace equipment threads, retorts, kilns, ovens, etc., exhaust system bolts and studs, cylinder head gaskets and studs, turbine casing studs and marine and coal mining equipment; farm equipment, heavy equipment trucks, cars, industrial equipment, drawing and forming of metals. Seems like it would be pretty good and would definately stick.
