Max Buffalo with no power
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
Thread: Max Buffalo with no power
  1. #1
    I just purchased a 2003 Max Buffalo. I am new to aatv ownership and know little about the t-20. It has 50 hours on it and has sat for a few years. It seems to drive fine on flat ground however I could not get it to drive up the ramp to the trailer I used to get it home. A friend pushed while I was driving it up the ramp to get it on. I have yet to really look into potential issues with the Buffalo and was wondering if anyone has any suggestions on where to start looking into the low power problem.
    I have not done much to it yet. Before starting it I put fresh gas in it. The tank stank like very stale gas and there was only a few oz of old gas I could not drain out. I pulled the plugs and they appear somewhat fouled. So I will be getting new plugs. I will be changing the fluids also. Any other maintance situations would be welcome.
    Thanks.
  2. #2
    Join Date
    Jan 2011
    Location
    northern Wisconsin
    Posts
    892
    Sounds like you're off to a good start. I would also put a new belt on and clean the clutch faces.
  3. #3
    Join Date
    Oct 2007
    Location
    statesville, north carolina
    Posts
    2,604
    First question: were you pushing hard forward on the sticks, or relying on the springs to do it?
  4. #4
    I was pushing on the sticks. Maybe not hard but I was pushing forward. Nothing sounded like it was slipping and the motor did not sound like it was working harder.
    Just checked the range of forward movement on the sticks and they really do not move forward much. I would thing that the slight movement oould not move much back to the t-20 due to The slop in the rods. So what should the first adjustment be? How far forward should the sticks move on a properly adjusted machine.
  5. #5
    Join Date
    May 2007
    Location
    Kings Mountain, NC
    Posts
    7,788
    Try it again by pushing hard on the sticks like racerone3 mentioned.
  6. #6
    Join Date
    May 2009
    Location
    NJ 08533
    Posts
    5,052
    Where are you located? Just curious?
    Check the belt also, it should just cover the driven clutch when engine is off.
  7. #7
    I am located in western new York. I had some issues getting able to post to the form and have yet been able to figure out how to update my profile. To be honest it have no tried to hard to figure it out, have been messing with my Buffalo in my limited free time.
    I think that the belt maybe just about 1\4 inch down on the clutch wheel when the motor is off. I will confirm this tomorrow
    Thanks for the situations.
  8. #8
    Join Date
    May 2010
    Location
    Fairbanks AK
    Posts
    1,456
    When you get it running get a tachometer and see what full throttle RPM is with the belt installed. It should pull 4000-4100 RPM if everything is correct.
  9. #9
    Join Date
    Apr 2016
    Location
    VT
    Posts
    266
    Hi
    For my 2 cents....I am restoring a 1996 MAX II. When I got it, it had little to no power. I found a post (http://www.route6x6.com/howto/carbclean/index.html) and did a complete carb cleaning, replaced all the gas line, filter, pump. Drained and flushed the tank. Added a fuel cut off valve. When I was done, the engine ran fine.
  10. #10
    I do not have the motor running 100% yet, but close. My issue does not appear to be a motor issue but a transmission issue. She seems to move fine on level ground but will not climb up an incline. I just ground down a scocket to adjust the tranny. We will see if that helps.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
