74 max 2 chain and sprocket upgrade ???
+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thread: 74 max 2 chain and sprocket upgrade ???
  1. #11
    Join Date
    May 2009
    Location
    NJ 08533
    Posts
    5,049
    As far as I remember all 40 chain frames were originally sprocket tensioners
    Edit, disregard that as I'm an idiot, the Turd is 40 chain with plastic style adjusters. The 40 and 50 chain machines were out together with the HP determined ing chain size.
    , all plastic ones should be the same width.
    Sprockets were 22 tooth on the 50, though I don't remember if the triple sprockets had different center counts.
  2. #12
    Join Date
    Feb 2013
    Location
    shenendoah valley,va.
    Posts
    2,627
    if need be you can get the # 50 type blocks off the floating chain tensioners that mcmaster carr sells. ( snap-idle) they also sell different style hard plastic channels for # 50 chain. good luck, j.b.
  3. #13
    Join Date
    Jan 2014
    Location
    clifton IL
    Posts
    812
    Thanks everyone he hassprockets ordered and 6 new rawhides on the way too. Should be ready to roll by April for sure!! This machine will be a trail/toy and also a 2 stroker so be prepared to smell some smoke at pine lake in june!! Lolol
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
