I googled the Alsport Tracker, a very different looking snowmobile. Its a two seater twin track machine, very need. I never heard of it, only the Raider twin track rig. So your saying the running gear in this rig will disengage the inside track when turning and if needed you can brake just one track? Can you share photos of the running gear and how it works?
I am wondering if the transmission in the Surbar 660 I am going to use is a limited slip and if I can just keep and use its engine to power the rig. I could put independent braking on the rear wheels and then run chains to two more wheels in front of it. Would need to get rid of the suspension....
Hmm I guess if someone could explain how limited slip trannys work and how to test if one is limited slip.
Thanks for the idea guys!
