1998 Max II owner looking at buying an older Max II project needs help
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
Thread: 1998 Max II owner looking at buying an older Max II project needs help
  1. #1
    Join Date
    Aug 2016
    Location
    North of Twin Cities Minnesota
    Posts
    22
    I was looking for some help from you guys. I checked out a craigslist ad for an argo project for $300. When I get there it looks just like my Max II. Major differences are a 2 stroke motor, fiberglass body in bad shape, and little 3 bolt hubs. All drive train seems ok but upper body is so bad I couldn't find any serial or model numbers. Is this a Max II? What approximate year is it? And is it worth $300?
    Ill appreciate any help into this.
  2. #2
    Join Date
    Aug 2016
    Location
    Posts
    22
    I also don't know much about the original tires on these old maxes. I've heard about "balloon tires" like I see on argos. I think this had them with tiny 3 bolt hubs. Are these stock?
  3. #3
    Join Date
    Sep 2012
    Location
    Hanover,PA
    Posts
    1,012
    Best if you could get some pic's of it. That way we can see what your looking at.
    The price doesn't sound bad but then again I am not looking it over ?
    You should fill in your Profile so we know where your at That way someone on here may be close enough to look at it with you ?
  4. #4
    Join Date
    Aug 2016
    Location
    Posts
    22
    Good point, I filled in my profile. I am picking it up Saturday morning for $200. For that price if it's in too bad of shape I can always use for parts or make something with it. Thanks
  5. #5
    Join Date
    Sep 2012
    Location
    Hanover,PA
    Posts
    1,012
    It should be worth that in parts alone.
  6. #6
    Join Date
    Jun 2007
    Location
    Buffalo, NY area
    Posts
    2,968
    Here's the craigslist ad.... It does look to be a Max II.
    https://minneapolis.craigslist.org/a...996676337.html
  7. #7
    Definitely an early MAxII
  8. #8
    Join Date
    Aug 2016
    Location
    Posts
    22
    Yep that's the one. It's loaded up and he's delivering it tonight I guess. So how early a Max is it? Early 70s?
  9. #9
    Join Date
    Aug 2016
    Location
    Posts
    22
    Since the fiberglass body is junk and I noticed the tub is full of holes and cracks I was thinking of just using the frame and drivetrain and making a 6 wheeled non amphibious atv. Has anyone ever done anything like this? I assume also the tub helped strengthen the frame from twisting and bending. Any input or opinions would be helpful. Otherwise Ill just be selling off whatever parts I can.
  10. #10
    Join Date
    Aug 2016
    Location
    Posts
    22
    Nobody has any input on this?
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
