Oops did not.
Oops did not.
Its all leverage, by moving the ,we'll call it , fulcrum point out the force the axle can withstand is greatly increased. The reason for the rails best I can recon is so the outer frame rail can't flex thus snapping the middle of the axle as it fights the inner frame rail.
Just going to throw it out there does anyone have a better idea for axles. I'm thinking can you retrofit a larger diameter axle.
Definitely doable. I see 3 ways to get it done.
1. Find a bearing with the same OD as you are currently running, but with a larger ID, assuming they make them to fit your flanges. If not, you'd have to find some different flanges that would house the bearings you wanted.
2. Cut the axle holes in the frame wider, reinforce the frame to make up for lost material and geometry, drill holes for the bolts of a larger flange that will house a larger bearing. Open the holes in the tub as necessary.
3. Build 6 extension units that would house larger ID and OD bearings and bolt them to the frame through the current flange bolt holes, though you'd get a decent amount of flex, and a lot of beefing up and geometry would have to happen to support them.
For the inners, I don't think I'd modify anything except the axles. Use a lathe to cut the ends down to whatever ID the inner bearing is. Hustler did that to their axles to get 1" ID bearings on the inners, and 1.25" ID bearings on the outers.
Meep Meep
I'm curious, are you running front chains with the tracks on?
No the reason I posted about chains was. I saw them when I was looking for tracks and I see where a lot of guys up north use machines for ice fishing. So I figured I'd put them out there, I didn't know that they made them for aatv tires.
OOPS1 I think we are talking about two different types of chain!! I think that Argo Jim is asking if you have removed any of your Axle Drive chains because you are running tracks? If I am confused , it isn't the first time and I apologise. Hey Delduck would I ever love to see the movie.
You can step up to 1 7/16 axles.i believe that is as big as you can go with the factory flanges for a 72mm bearing. I just made a set for my max iv. Old vs new
The bearing part # i used is. uc207-23r3
