TheSilverBuick MAX II Project
+ Reply to Thread
Page 6 of 6 FirstFirst ... 4 5 6
Results 51 to 57 of 57
Thread: TheSilverBuick MAX II Project
  1. #51
    Join Date
    May 2007
    Location
    Kings Mountain, NC
    Posts
    7,788
    Looks good. How much did they have to take off to get it smooth? It didn't look too terribly bad in the previous photos.
  2. #52
    Join Date
    Feb 2017
    Location
    Sparks, NV
    Posts
    85
    I believe the machinist said between .010" and .015". I gave him direction to cut down until the bevel on the edge is gone if necessary, but no further. If it didn't clean up by then I'd take it as cleaned up as that, but it still has some bevel left so not bad at all. I'm not sure if these are machined like car brake rotors or not, but the cheater method of telling if a brake rotor can be cut or not is the bevel on the edge, they can be cut until the bevel is gone, so I took that approach here.
    Said it only took him 15 minutes and cut like butter, Easy $40, not sure why so many shops had a problem with trying it or putting it off.
  3. #53
    Join Date
    Jan 2014
    Location
    clifton IL
    Posts
    812
    Did they just have to take off a little bit or try to build up and machine off?? These are cast correct?
    Lol. Never mind. I just read post above mine! My bad
  4. #54
    Join Date
    Jun 2007
    Location
    Buffalo, NY area
    Posts
    2,968
    Quote Originally Posted by TheSilverBuick View Post
    I resurfaced a set of four drums for a forum member a few years back. Visually, they were beat up pretty bad, but only need about 0.020" taken off for a reduction in diameter of 0.040". There was an old argument that machining the drums was a bad idea because they become too small for standard bands, and the plungers are going to stick out of the case too far. Sure, they stick out a bit more but it's negligible. The drums are nice and soft and machine nicely. There's plenty of material there and it only makes sense to reuse them where possible.
  5. #55
    Don't leave us hanging bro!
  6. #56
    Join Date
    Feb 2017
    Location
    Sparks, NV
    Posts
    85
    I got busy! Got another one of my cars to the house from across the state as well as my utility trailer that I'll use to move the MAX around.
    My current issue is, I got the transmission together (thank you for the guides on the main page!) but before I put it back in I was trying out the shifting and I cannot get left side to engage forward. The shifter is simply won't go. It'll do neutral and reverse. I haven't had the time to mess with it more, either play with the bands and turning the input shaft to see if I can get the drum to rotate or a complete disassembly to see where I went wrong? I'm hoping to get it sorted out this weekend.
  7. #57
    Join Date
    Feb 2017
    Location
    Sparks, NV
    Posts
    85
    I pulled it apart this morning and it appears that the thrust washer between the drums on the one side slipped out of place keeping the shifter from moving in that direction. I put it back together and both sides appear to shift fine. So now I can get to putting it back into the machine.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
