Alternative windshield supports
+ Reply to Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
Thread: Alternative windshield supports
  1. #1
    Join Date
    Jun 2016
    Location
    Edgerton, MO
    Posts
    278
    Thanks to member Jezzah, I now have a windshield on the way. Does anyone have a recommendation on something I can use for the side braces/supports? Any ideas appreciated.
  2. #2
    Join Date
    Mar 2012
    Location
    South Shore MA.
    Posts
    157
    Not sure what you are looking for but I found Bimini top hardware on sale/ clearance at a local boat dealer , and made my own windshield here's a link to my gallery ...
    Homemade Argo Windshield and Soft Top - Amphibious ATV Pictures
    Good luck and be safe
    bg
  3. #3
    Join Date
    Jun 2016
    Location
    Edgerton, MO
    Posts
    278
    I'll check local boat dealer, Jezzah sold me a windshield with the hinge, but I am going to need something to use in place of the bars that hold the windshield in the upright position. OEM unit has bars that go from upper body to windshield frame and stow on upper body side when windshield is folded, I believe.
  4. #4
    Join Date
    May 2009
    Location
    NJ 08533
    Posts
    5,052
    Go to a marine store and purchase what is needed to make the windshield mount like the current style, be sure NOT to drill the holes THROUGH the GLASS or you'll be buying that also.
    If you wish to make it like the older style (which it is) if the loops are on the back and screw holes on are the front, a piece of cable goes on the front with bungee cords on the rear side.
  5. #5
    Join Date
    May 2009
    Location
    NJ 08533
    Posts
    5,052
    No need to remove bungees to fold windshield.
  6. #6
    Join Date
    Jun 2016
    Location
    Edgerton, MO
    Posts
    278
    Thanks so much Jim, I had no idea there were two methods, guess I'll see if windshield is new or old style and mount accordingly
  7. #7
    Join Date
    Apr 2015
    Location
    Indiana
    Posts
    48
    I used thin wall conduit, also called EMT. Flattened the ends then drill flat areas so they can be bolted to frame and body. That seems to do well. Good luck.
  8. #8
    Join Date
    Jun 2016
    Location
    Edgerton, MO
    Posts
    278
    Thank you
  9. #9
    Join Date
    Oct 2010
    Location
    Wells Maine
    Posts
    98
    That windshield came off of an early 70's Max II but i can't say for sure if it was put on later or not. I hope it works out for you.
  10. #10
    Join Date
    Jun 2016
    Location
    Edgerton, MO
    Posts
    278
    I'll make it work
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
