Max production delay
+ Reply to Thread
Page 8 of 8 FirstFirst ... 6 7 8
Results 71 to 75 of 75
Thread: Max production delay
  1. #71
    Join Date
    Jun 2007
    Location
    Phoenix,Az.
    Posts
    1,629
    whipper
  2. #72
    Is the new company going to produce parts for those of us who are antiquated and still own/operate the early machines? I personally have
    a 1990 Max II that is still going strong. Here in Georgia, there are very few amphibs outside the BIG CITY.
  3. #73
    Join Date
    Jul 2008
    Location
    Sarasota, FL
    Posts
    369
    Any updates on the status of Max?
  4. #74
    Join Date
    Jun 2007
    Location
    Central NJ
    Posts
    1,470
    Quote Originally Posted by TheSilverBuick View Post
    The sorta nice thing about using an open carrier differential and braking is when brakes are applied to one side the other side receives all the power scrubbed off the braked side, or double what it had before for full braking. I haven't worked out the power flow through the T-20 to see if the power is pushed to the other side, but I don't think it is. A fair number of modern cars use the ABS system to cheat the system like this with traction control. When one side starts to slip the ECU applies the brake to the slipping side to push engine power to the wheel with more traction.
    Argo has used an open diff for many years and will require additional power to turn while climbing. The T-20 does not. The only other trans that is more efficient than a t-20 is a fully clutched system.
    Acta non verba
  5. #75
    Join Date
    Aug 2011
    Location
    Kotzebue, Alaska
    Posts
    1,209
    An Argo is also not true 6 or 8 wheel drive either. Its one side drive. One has to apply brakes to the side that spins (wasting power) just to move power to the side that has less.
    Its not so much of a problem with proper driving technique though.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
