Just wondering how long others get out of their inner/outer axle bearings. I have an '04 max 2 that I've changed bearings in once...I think the meter has 300 hrs on it
If you clean and use a good grease thy should hold up for a Long time.
DSCN0457.jpgDSCN0458.jpg HI, I bought a Swamp fox that had the original bearings in it and they were still serviceable. They last a long time as long as they are not abused to excess and don't sit full of water....... grease is cheap, bearings are expensive. Learned that farming.....PMs are the secret to longevity!
We changed out a few bearings on a few axles over the past few years. We grease often, but I have absolutely no proof grease gets into that tiny hole. Where does the grease that was in it from the factory go, if the bearings are sealed?
In my opinion stamped steel flange bearings are the cheapest bearings known to man kind and are the biggest flaw of any AATV. There should be at least 3 bearings per axel standard with the center bearing completely packed in grease to the keep water out of the bearing and seal the tub as well. Amphibs eat bearings for breakfast. Like Rusty says when you grease very little if any grease gets in the actual bearing itself and the grease that is in there gets washed out from water leaking past the seals. I've seen bearings start to go after only 100 hrs if used in water a lot.
2001 Max IV with 1000 hrs. Still running on original bearings. Replaced bearings FR inner &outer when replacing bent axle. Though damaged from bent axle, they were full of grease and otherwise OK. I don't do many amphibious operations though. All in the maintenance.
