I have a 1995 Max II with 104 hours on it. Recently one of the 4 chain tensioners' failed. I used "buggyman1's" design and installed it today. The one that failed was the one right in front of the driven clutch. By far the worst one as far as access goes. The other 3 should be much quicker and easier. I was able to remove the old tensioner, fabricate the new and install it in about 3 hours. The other 3 are holding tight, so I will replace them as they fail. I took it for a short ride and it seems to be working well. I will keep an eye on it and report any issues if they arise. I ordered the HDPE plastic tube and unistrut from McMaster Carr and picked up the spring nuts at Lowes. Total cost for 4 tensioners is around $25.00. Big thank you to "buggyman1" for sharing his idea/design.
This is the old tensioner with unistrut welded on the back and springnut in place.
This is the bolt/HDPE roller/washer prior to bolting it in place.
This is where it gets bolted in (2 bolts on top and 2 on the bottom). Very tight access, but it can be done without removing anything. It goes where you see the 2 square holes. Took several tries and lots of patience to get the nuts on the bottom side, but it can be done.
