The most common crank shaft it 2 29/32 (just call it 3 inch). I typically just build a spacer or stack up washers to fill the void inside the clutch so that the fender washer holding the clutch in place has something to tighten against.
16 to 20 hp would make a noticeable difference. If you are sure of the hours on the Honda and it will either clean up ok, or you can live with ugly then I would grab it. that is a great price and should last a long time. there shouldn't be much/ anything galvanized on it. what you are probably seeing is the aluminum is oxidized
