| Max ATVs Forum for discussing all Max 6x6 Atvs from Recreative Industries including the Max II, Max IV and the Buffalo truck. |
LinkBack | Thread Tools | Display Modes |
If the fuel was the case it would miss, chug-a-lug untile it clears out and smoke alot of black smoke at first start up. It wouldnt start at all if it was enough gas to hydro-lock the engine. You would also most likely have alot of gas in the oil.
__________________
Attex 208/TT Attex 225/Hustler |
Yes, why not clean out the carb? Always a good idea if your not sure it's clean. I would still trace each wire between battery and starter motor (+) AND between Battery and ENGINE BLOCK (-) The battery to frame may be fine, but since the engine is probably on rubber mounts, there is a groun strap and if that is a little loose, your motor will stall the second it loads and tries to draw too much current. (It would Clunk, but then not crank, and you may hear the solenoid rapidly ticking, or not, depending on where the loose connection is). Good luck making opening day!
__________________
Where's the steering wheel?
Just a thought.. you could put an amp clamp on the line to the starter. If during the "Clunking" you get a huge increase in current than something is blocking the engine from turning. If you get nothing during the clunking than its something electrical.
| Thread Tools | |
| Display Modes | |
