Amphibioius Atvs Logo
Go Back   6x6 World > 6x6 ATVs > Max ATVs
Max ATVs Forum for discussing all Max 6x6 Atvs from Recreative Industries including the Max II, Max IV and the Buffalo truck.
Reply
  #1 (permalink)
Old 10-02-2008, 11:51 AM
smokin cigarettes's Avatar
smokin cigarettes smokin cigarettes is offline
Sophomore Slider
smokin cigarettes is on a distinguished road
Looking at a 1992 max iv
Is there anything to be wary of with this old of a machine? It has been in storeage and has less than 50 miles on it. It looks brand new.
  #2 (permalink)
Old 10-02-2008, 12:06 PM
liflod's Avatar
liflod liflod is offline
Amphibs R us
liflod is an unknown quantity at this point
The machine probably does not have the solid splined axles and has the smaller diameter outer bearings. If the machine has very low hours, you should not have problems. Get the wheels off the ground and check for play in the axle/sprocket connections and the outer bearings. If everything is tight, you should be good for many many miles.
What engine is in it? I would not expect that machine to be worth much more than $3k depending on condition. If you plan on running 26" tires and a larger engine, you may want to hold off for a 1999 or newer machine with the splined axles. The machines with the rectangle(2001 ?) headlights offer a few more inches of room for the rear passengers.
  #3 (permalink)
Old 10-02-2008, 12:18 PM
Sophomore Slider
Thanks for the quick reply!
I called recreative and they said that it had the solid axle upgrade. 25in tires and 20 kohler engine.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
