Max II struggle to get through snow
I have a Max II with new 23 hp Vanguard and new clutch. Belt and chains are properly adjusted. Just got 8 inches of new snow. Thought - well here it goes. Drove out of garage and down slight grade hill. Coming back up almost couldn't make it with the tires spinning. 4 wheel ATV probably would have worked better. Very disappointed. Thought about getting wheel extenders and maybe chains. Not sure if that would work much better. Tracks are very expensive - have a used pair of Argo tracks. Seems as if it would take a lot more hp to push like the videos I have seen on Youtube. Any suggestions? Thank you.:hmmmm2:
max 11 struggle to get through snow
:hello:
Quote:
Originally Posted by
flippy
my max did fine riding on top of deep snow,then it just hit a spot where it dropped into the snow and the tub bottommed out and all 6 wheels just spun,I had to dig it out.I dont think the 6x6's are good in deep snow unless they have tracks at least my machine isnt.
you are correct. that includes 8 wheelers also. jeffery9067 put it better above but tracks make them almost unstoppable in snow of any depth and less than your 23 horsepower is fine. if you get the spacers ,measure the size of each tire and put them on as per directions you will have a winning combination. good luck
