anyone have the right no.s for a stp or fram oil filter for a briggs vanguard twin cylinder 21 h.p.motor . auto store can't seem to cross reference it with the briggs filter . thanks jboy
Printable View
I'm pretty sure this is what you need, https://www.fram.com/parts-search/PH...djzDTLH7bjAukA
howling ...that's the same fram no. i found online . went to auto zone and advance auto and they had no fram filters starting with ph . looked like all the no.s had been changed . stp filter online for that motor says it's a stp4292 so i'll check that tomorrow . that filters
howling ... that's the same fram no. i found online . neither auto zone or advance auto had any fram filters starting with ph . looked like they changed all the filter no.s . i found online that the stp4292 filter will work , so i'll check tomorrow . it's $ 14.......thanks , johnboy va.
John. Have you tried Napa auto parts ?
thanks 449 ...i'll stop by and check them out . j.b.
no luck with stp or fram oil filters at any auto parts . got a briggs filter at lawnmower shop . jboy
Napa 1348 or Wix 51348 from O'Reillys Autoparts, they are all I ever use.
thanks jww ...i figured there must be some filters other than briggs . i'll write it down , ready for the next change . have fun , johnboy va
I ended up with a baldwin b7615 that was available locally
Awesome I have only had luck finding Briggs filters as well. Nice to have other options.
