Larry, i'll send you a pm with my # so you can call/text me if you get time to come by.
Printable View
I am still conflicted on what material to use for the flooring. Pipe dream would be to use a thick Lexan type material that can be see-through. It is always a pain to see a problem after the fact with the factory floor boards hiding things. If the material was see through you could keep an eye on things easily, such as a worn/wobbling part, etc.. Tasks like greasing the chains could be as simple as drilling a hole in the floor for inserting a spray can (whatever that red extension is called on a spray can) and just spray on-the-fly until you see it has covered the chains properly. A few holes in particular places would make this task doable by an extra occupant while the driver drives back and forward in the yard. No need for a ramp or jack to raise the machine. The reality is whatever I use it needs to be as light weight as possible. If I go too heavy (and use the thickness of an item to help control noise) I end up compromising the payload I’m capable of having. That’s not an enormous problem for me but it's something to consider and keep in mind. If I do a see-through floor the chains will sling up oil decreasing visibility. That can be resolved by an occasional cleaning regimen. I have other options but in reality my pipe dream option is what I really want. My idea of a new floor would help with noise but it also would greatly reduce the sand/dirt, and foliage that would enter the tub. Since I operate in Osceola National Forest I’ve got swamp conditions combined with tight ground cover that can be very tall to overcome. My tracked max has no problems getting around in this stuff, but every broken leaf, stick, bug, and anything else that’s floating around as I move around gets deposited right in the tub. We all know that just adds to the cleanup time and it can also add more unforeseen problems to an already maintenance heavy atv. Any ideas from anyone else?
Ok, if thats stock...it certainly is larger than the factory one on my max. Now just need to find that right for me muffler.
hi
99% mower mufflers donot have any sound absorbing material . Quality sound absorbing material used by oem can be expensive if available
Very thin single layer steel casing material -transmits noise easily
There physical size is small --reducing sound absorbtion capalbilities
99 mower mufflers are an exhaust redirection device
twin and triple noise dampening chambers as per auto industry mufflers do not exist on mowers etc
An 1 1/2 inlet/outlet triple pass auto muffler sounds ideal
Intake noise and cooling fan noise will still exist
Fit noise reducing products to engine cover
A heavy wall /barrier is highly recommended to help noise reduction . A light weight barrier vibrates therefore transmiting noise .
Noise pollution is hard to remove and requires a multi situation approach .Sound studio construction and generator noise reduction is a prime example of this subjet and how challenging it can be .
tomo
I sent off information letters to two lexan plastic companies last night, looking for opinions on their products for my floor project. Hope to hear back from them soon
HI,
The easiest solution would be to use that dynomat stuck to the underside of the original floor pan.
Overlap the edges and if required use aluminum plate as trimming to take up gaps etc
The benefits would include
cost effective
easy install
the total weight would be greater than another style of plastic---------- weight = sound absorbtion
APPLY 2 LAYERS IF NEEDED
The alloy sheet side is oil proof -easy to clean
tomo
Has anyone tried the add-on mufflers that being sold for four wheelers?
