mike i didn't know it would run that fast
Printable View
I'm sure everybody here wants to help you but they're all like me. I've never clocked mine and haven't a clue how fast it'll go.
I put more shims under the motor and tightend the belt and it still only runs 15. And the rpm gauge thing is not available at any auto parts store that I've looked. And a lot of people clock their speed on these, mike will tell u that also.
on my old max with the 26 tires and 20 hp kohler with the gov. adjusted for slightly higher rpm's... it GPS'ed at 21 mph. all i can
suggest is to make sure your clutches are ramping all the way in and out
It should go faster than 15. My Max IV easily goes 15 down our local 3rd St, near the school zone, which has a vehical speed guage. We can see our speed at a glance (its mounted to the speed sign). I do 15 at about half throttle. BTW I've never been full throttle yet.
Looking at the pictures the belt has some wear I'd start there if you can't find a mower shop to test the rpm's. I'd like to say something about the clutch but that will wait.
According to an older brochure the 16 Tecumseh IV tops at 20 mph, however there were 3 tire options available ( the 21, 23 and 26 ) and not sure as to top speed per tire or which does 20 mph. A 26 will eat a 21(closer to 19.5 or so on 8x8 rims) for lunch on flat ground.
Thanks Jim, and please feel free to say what u want about the clutch, I need all the help I can get. Can I just cut the belt off and take it to a mower shop and let them give me the same one or since it has wear will it be stretched and measure wrong?
I'd suggest a new belt from the factory or an aftermarket belt that msafi65 posted the number of.
I'd remove the belt and learn the trick (if there is one) so you can put the new one on without damage.
Take a picture of the new belt in the drive clutch before I comment.
Ok will do! thanks everyone for the replies!
ok so I got a new belt and it didn't help my speed at all. Any other suggestions??
