thanks guys for the replies. going to buy a set for the max 2. i guess you could run over a stump or something just right and pull the plug. but under most cases they sound like they have been proven to work well. johnboy va.
Printable View
John, check the sizing of the plugs and your drain holes before ordering. I made the mistake of ordering a bag of the drain plugs from Maximum Off Road on eBay and they DO NOT fit a Max IV as advertised. I have an entire bag of the plugs that I would guess fit a hole in the 9/16ths to 5/8ths range.
I remedied the problem by going to the auto parts store and looking on the Help rack and locating a pair of rubber differential plugs. The hole in my Max IV (and I have no idea if it's the original size) is 7/8ths. Anyway, the diff plugs are pretty heavy duty and I don't see them being destroyed after multiple uses nor do I see them leaking.
Bottom line, verify the drain hole sizing before buying, don't assume because the seller says they fit model XXXX that they will actually fit. My fault for not checking the size, not the sellers.
The ones you were sent are probably the correct ones. I believe they should be 5/8" diameter. It sounds like your drain plug holes were worn out. That's not uncommon. My Max II was worn to where the smaller cap plugs wouldn't stay in. I drilled out to 7/8" and bought some 7/8" plugs.
Our drain plugs fit every Max model ever made, they have never been changed. The problem you ran into was that someone has drilled out the holes in your machine to fit a boat plug. Plug holes can also be damaged by people removing plugs improperly. A quick call or email to us would have answered your questions about these plugs, and of course you could just return them. All Max factory drain plugs are 3/4".
Update... Regarding the plugs from Maximum Off-Road, the plugs fit very well. I got my 40-count bag in and these fit good. I'd buy from them again.
