For bypassing the governor we cut the cable attachment point off its mount, flattened it and bolted it to the intake on the other side of the motor. The Zbend in this kit will attach it to the carburetor or you can find this kind of thing at the local lawn mower shop. Just removed the governor arm, the internals will come out next time the motors pulled. I will post a pic next weekend when I get home.
Universal Cable Repair Kit | Lawn Mower Parts | MFG Supply
1 Attachment(s)
This is the predator engine wiring diagram
Attachment 15990
I deleted the fuel solenoid and oil level wiring. You have to remove the carb and pull the solenoid to remove the needle valve on it and then reinstall the solenoid. After that its just three wires charge start and kill. I have this in a big PDF too large to post, anyone that wants it just PM me your email.
2 Attachment(s)
For a governor delete I removed the governor arm off the shaft and sawed the throttle attachment bracket off.
Attachment 15991
Then I hammered it flat and ground on it a little, then bolted it to the intake manifold on the right side of the engine to reverse the pull direction.
Attachment 15992
PM sent for info on the wiring, got mine installed and stumped with the wiring portion.
