Serial Number Year Model Username
0552 1970 Max II Waud
2966 197? Max II Swfleur Kawasaki 440a stock upgraded to a 4-stroke
3095 1973 Max II Kunzmm137
3164 197? Max II Whitefisher
4238 1974 Max II Jasonku
4270 1974 Max II Msafi65
4382 1974 Max II Dano1877
4729 1975 Max II Radioactiveboyscout
4984 197? Max II Rsashurn
5398 1980 Max II Dano1877
5949 1980 Max II Dano1877
6001 1980 Max II Yogi1644
6479 1980 Max II BRB
6677 1980 Max II Cementhead
6864 1980 Max II Dave Smith
7127 1983 Max II Mad-max
7??? 1983 Max II Applejack
7400 1985 Max II Adondo
7462 1985 Max II Drewstang
7664 1986 Max II Gravel128
7751 198? Max II Msommer
8270 1989 Max II Duncan
8323 1989 Max II Swfleur factory Tecumseh OH180
8491 1989 Max II River2406
8985 1990 Max II Coosaridgerider
9344 1992 Max II DZG
9459 1992 Max II Rottsrool
9668 1992 Max II M38inmaine
9710 1992 Max II Iwantonetoo
10055 199? Max II Snake stomper
10216 1993 Max II Tattooman
10493 1993 Max II JPSwift1
11212 199? Max II Warpony1
11588 1995 Max II Normable
13270 1996 Max II JPSwift1
14177 1998 Max II Outdoorsy74
14951 1998 Max II Newargoowner
15306 1999 Max II Johnnova
15327 1999 Max II JPSwift1
15646 1999 Max II Aetractor
157XX 1999 Max II Monoped
16063 1999 Max II Johnt
17059 2000 Max II (SS) Model Citizen
17335 2001 Max II MaxII420
17545 2001 Max II Tplayer49
17636 2001 Max II Jonjon6x6
17752 2001 Max II Bigfoot Thebuggyman1
18564 2002 Max II CBass Current 18 HP Block bore out like a Bando
18842 2003 Max II Eldon
19002 2003 Max II Gambler
19134 2004 Max II Carbidegrinder
19794 2006 Max II Johnnova
21439 2013 Max II RI/Mudd-Ox [Last NY built]
6381 1980 Max IV Wildcard
7329 1984 Max IV Fishfreak11
8036 1988 Max IV Maxoverdrive
9212 199? Max IV Anotheramature
9298 1992 Max IV Green 20 HP Kohler Magnum
9575 1992 Max IV PAMike
10161 1993 Max IV Jnrmoto
10164 1993 Max IV North Country Tough
10375 1993 Max IV Rickemd1
10410 1994 Max IV Blown84gt
10456 1994 Max IV JPSwift1
10586 1994 Max IV Phabib
10621 1994 Max IV Steelheart
10732 1994 Max IV Sgtlane04901
10904 1994 Max IV Jacobsrf
11386 1995 Max IV Millerperf
11530 1995 Max IV Countrycummins99
11582 1995 Max IV BadBradII
11640 1995 Max IV MAMudslinger
12002 1996 Max IV Dozerlarry
12300 1996 Max IV Hiballer211
12896 1996 Max IV Coyote
14131 1997 Max IV Plumcrazy
14428 1998 Max IV Jtb51b
16228 1999 Max IV Tennesseemudbug
16258 1999 Max IV Newtwo6x6
16398 2000 Max IV Amphibious Drew Factory 16 Vanguard upgraded to a 23 Vanguard
16999 2000 Max IV Kjmax4/Fmints
17165 2000 Max IV Xbunsenx
17319 2001 Max IV JPSwift1
17573 2001 Max IV Wheeler
18204 2002 Max IV Amphibious Drew
18536 2002 Max IV Kghills
18837 2003 Max IV Drooper
19117 2004 Max IV Ww2imposter 25 HP Kohler Command
19274 2004 Max IV CBass Factory 23 HP Kohler
19679 2005 Max IV Rusty-Gunn Factory 25 HP Kohler Command
9157 1991 Buffalo JPSwift1
15065 1998 Buffalo BuffaloChuck
20277 2008 Buffalo Akranger72 Factory 23 HP Kohler Command
20356 2009 Buffalo Ktcole
20718 2011 Buffalo IanPNG
20739 2011 Buffalo IanPNG
10539 1976 RIM Millirad
10544 1977 RIM Brentelsheiemr
Total Max Count thus far: 98
Currently 2005 Buffalo trucks
19350 Complete
19352 Complete tracked
19353 incomplete
19424 incomplete for the moment
19427 incomplete
19571 Complete
19350 2005 Buffalo Argojim
19352 2005 Buffalo Argojim
19353 2005 Buffalo Argojim incomplete
19424 2005 Buffalo Argojim incomplete for the moment
19427 2005 Buffalo Argojim incomplete
19571 2005 Buffalo Argojim
Total Max Count thus far: 104
Year model Max Buffalo
We acquired a 1989 (I Believe) Max Buffalo truck with only 235 hours on the engine a an auction. The rancher had quit using it when he broke the throttle cable. It is in god shape but the mice had been living in it the past 15+ years it sat in the rancher's shed and their pee ate a hole in the block (fixable) and destroyed the starter mounts (not fixable). I re-engined it with a 20 HP Vangaard from a partially burned lawnmower, bought a new clutch to fit the larger shaft, and am learning to drive it. It wants to pull to the left all the time and I wonder if the 25 year old tranny grease may be the fault, unless there is some adjustment for this. The previous owner had enlarged one of the drain openings and I am going to try to repair it to use the standard plugs and make her waterproof. I also wonder about the seals in the axles. 3 tires leaked air so I put tubes in them. I'll likely do the same with the rest. We have a cabin in the Black Hills and a small damed up lake I want to try it in. Using if mainly for moviing logs and occasional use on the trails. Hope to have a lot more fun with it.
Noelchico
Purchased a 1989, I think, Max Buffalo at auction. Seriel # 8331. the Rancher can't find the title so I am going to try to licence it with the sales receipt. it sat for the past 15+ years in his shed as he broke the throttle cable on it. It only has 235 hours on the 20 HP Kohler engine but the mice got under the flywheel and at it apart, their pee ate through the block (fixable) and destroyed the starter mounts (non fixable) and starter. i re-engined it with a 18 HP Kohler Vangaard from a partially burned mower and had to buy a new clutch to fit the larger shaft. 3 tires wouldn't hold air for a week so put tubes in them. It wants to wander to the left under power. It may be the 25 year old tranny fluid unless there is an adjustment for this. Prior owner had enlarged one of the drain holes in the back and I'm going to try to fix that back to stock so I can use it in the acre pond behind the cabin. So far just learning how to drive it and get around.
Noelchico
7043 year??15817-99 max11 special ed.
15817 1999 Max II Special Ed
8331 1989 Buffalo Noelchico 18 HP Vanguard
Total Max Count thus far: 106
I have a 1979 Max 4 serial 6960. Has a kawai 440 two stroke. I believe i have the oldest max 4 on here am i right?
Judging by the serial numbers, I would say Wildcard has you beat, but his is listed as 1980.
6960 1980 Max IV Frankqpardoins Kawai 440 two Stroke
Total Max Count thus far: 107
