What is your idle speed? It sounds like the clutch is closing as soon as it is started.
Printable View
Yes sounds like idling too high, try 7-900 I run mine low.
If the idle is high and engaging the belt, then yes the springs will do that though not necessarily too tight. With the springs installed there is always engagement forward in forward or brakes in reverse, a high idle will basically give you cruise control effect with springs attached.
Figure that out first, then the top end thing. You didn't mention what size tires you have, a Max IV with 21's is not that ( 25mph) fast.
