Max iv diesel swap
Page 1 of 8 1 2 3 ... LastLast
Results 1 to 10 of 71
Thread: Max iv diesel swap
    Mar 2012
    Mercer, pa
    161
    Max iv diesel swap
    Picked up the engine for the diesel swap last nightime. It's a kubota d722. I will be putting it in my max iv. I am going to put the transmission under the seat in order to make room for the diesel and keep the cog as low as I can. This is my winter project so updates will be slow. Here is a pic of the engine.
    Aug 2011
    Kotzebue, Alaska
    1,209
    Cool. I hope it works out well. Interesting stuff.
    Mar 2012
    Mercer, pa
    161
    Well I managed to get some free time and the weather has been great the last couple days. So I got a good jump on the max project. Got it mocked up let me know what you guys think. Good or bad I would like to hear it.
    I look forward to watching your progress. Keep us updated. For your clutches, how close are they looking like they will line up?
    Mar 2012
    Mercer, pa
    161
    Clutches look like they will line up well. Planning on using a reverse wound secondary so that I don't have to remold the tub. I am going to try to machine my stub shaft down this weekend. It is 1 1/8 my clutch is 1" so I havn't been able to install the primary clutch yet.
    2,639
    miller, it looks great ... what h.p. is the diesel ? johnboy va.
    Mar 2012
    Mercer, pa
    161
    Thanks it is 20hp and 34 ft lbs of torque.
    Cool
    Thanks
    Ty Turner
    870-818-1315
    tyturnersoffroad@yahoo.com
    JESUS ROCKS
    Mar 2012
    Mercer, pa
    161
    A little more progress getting things ruffed in. I am going to run a polaris secondary which is 10 3/4 o.d. so i am going to have to pick the tranny up about an inch. I am also moving the tranny farther forward than i had planned. This is to shorten the drive chains a good bit. Downside to that is that it will take a pretty long belt. The engine cannot go forward anymore because off the backseat which i also moved 3" to the rear for more leg room. Battery will be off set to the right side of the machine. After going to my steel source i have decide this beast is going to be equipped with some massive 1 7/16 axles. Planning on finishing the motor mounts on monday i have some machining to do on them.
    Mar 2012
    Mercer, pa
    161
    Quick update got the transmission mounted and split shifters fabbed up. Waiting on heim joints to make the linkages. Also waiting on the adapter to mount the team clutch to the kubota flywheel. Couple pics for you guys.
